Knowledge Base Article
How do I determine the failing calibration stage for a Cyclone V or Arria V HPS SDRAM controller?
Description
To view the calibration debug information, you must turn on the debug output report by setting the RUNTIME_CAL_REPORT option to value 1 in the sequencer_defines.h file located in the hps_isw_handoff directory.
After boot and during calibration, the following statements will be printed in the debug output report if calibration fails:
SEQ.C: Calibration Failed
SEQ.C: Error Stage : <Num>
SEQ.C: Error Substage: <Num>
SEQ.C: Error Group : <Num
To determine the stage and sub-stage, open the sequencer.h file in the hps_isw_handoff directory and look for the calibration defines:
/* calibration stages */
#define CAL_STAGE_NIL 0
#define CAL_STAGE_VFIFO 1
#define CAL_STAGE_WLEVEL 2
#define CAL_STAGE_LFIFO 3
#define CAL_STAGE_WRITES 4
#define CAL_STAGE_FULLTEST 5
#define CAL_STAGE_REFRESH 6
#define CAL_STAGE_CAL_SKIPPED 7
#define CAL_STAGE_CAL_ABORTED 8
#define CAL_STAGE_VFIFO_AFTER_WRITES 9
/* calibration substages */
#define CAL_SUBSTAGE_NIL 0
#define CAL_SUBSTAGE_GUARANTEED_READ 1
#define CAL_SUBSTAGE_DQS_EN_PHASE 2
#define CAL_SUBSTAGE_VFIFO_CENTER 3
#define CAL_SUBSTAGE_WORKING_DELAY 1
#define CAL_SUBSTAGE_LAST_WORKING_DELAY 2
#define CAL_SUBSTAGE_WLEVEL_COPY 3
#define CAL_SUBSTAGE_WRITES_CENTER 1
#define CAL_SUBSTAGE_READ_LATENCY 1
#define CAL_SUBSTAGE_REFRESH 1
Refer to the UniPHY Calibration Stages section of the Functional Description – UniPHY (.PDF) chapter of the External Memory Interface Handbook for details on the calibration stages.
Updated 2 months ago
Version 2.0
