Knowledge Base Article
How do I debug a Nios® II system without downloading the program again?
Description
To open a Nios II debug session without downloading code, perform the following steps:
  1. Go to Run->Debug
  2. Select the configuration you want to run
  3. Select the Debugger tab
  4. Choose one of the following under Download and Reset:
    • Attach to existing program on target (no download)
    • Reset target and execute from reset vector (no download)
  5. Click the Debug button.
The first option in step 4 will attach to the current location being executed. The second option will attach and reset the program currently running on the target board.
Updated 3 months ago
Version 2.0
