Knowledge Base Article
How do I create a .vcd file and display the waveform in the ModelSim software?
Description
A .vcd file is an IEEE 1364-1995 standard file that contains all the simulation waveform information that is useful for debugging simulation. It contains all the signals in the design, so you do not need to rerun a simulation if you need to add a signal in the Waveform window.
To create a .vcd file:
1)    Compile and load design successfully in transcript window
2)    Specify VCD filename
-        Syntax:    vcd  file <file_name>.vcd
3)    Enable VCD to dump signals under a desired instance
-        Syntax:    vcd add <path_to_instance>/*
Note:  This command does not dump signals of children instances
                      Enable VCD for encrypted instances will generate warnings
4)    Run simulation generate VCD database
5)    Quit simulation
-        Syntax:    quit –sim
To be able to display the signals in the .vcd file in Modelsim Waveform window:
      1)    Convert VCD to WLF format in ModelSim
-        Syntax:    vcd2wlf  <file1.vcd>  <file2.wlf>
Note:  if the conversion fails, most of the time it is caused by non-existing instance path. Make sure the  desired instance paths specified in step 3 are correct
2)    Exit the current ModelSim session (needed for ModelSim for generate a proper VCD file)
3)    ModelSim session and open the WLF file created in the step 1
-        File menu -> Open -> file2.wlf
4)    Select signals for debugging in Object window and add them to the Waveform window
Updated 2 months ago
Version 2.0
