Knowledge Base Article
How do I create a .jam file to erase a MAX-series CPLD using the Quartus II software?
Description
You can create a JEDEC JESD71 STAPL Format File (.jam) file to erase a MAX®-series CPLD using the Quartus® II software by following the steps below:
- Open the Quartus II Programmer with a blank (un-programmed) MAX-series device. If the device has been programmed, use the Erase programming option to erase the device.
- Use the Examine programming option in the Quartus II Programmer and save the Programmer Object File (.pof) file to your computer.
- Add the blank .pof file in the Quartus II Programmer.
- From the File menu in the Quartus II Programmer, select Create JAM, JBS, SVF or ISC File...
- Enter a name for the file and select the file format JEDEC STAPL Format (.jam) in the Create JAM, JBC, SVF or ISC file dialog box.
- Click OK.
Resolution
Updated 2 months ago
