Knowledge Base Article
How do I compile the Programming Language Interface (PLI), convert_hex2ver.c, in ModelTech to simulate MAX PLUS® II output files for designs containing ROM or initialized RAM?
Description
Download the convert_hex2ver.c file from the EDIF web site (http://www.edif.org/lpmweb/convert_hex2ver.c).
  • Create a file called veriuser_mti.c with the following contents:
    #include "veriuser.h"
    #include "acc_user.h"
    extern convert_hex2ver();
    s_tfcell veriusertfs[] =
        /*** Template for an entry:
        { usertask|userfunction, data,
          checktf(), sizetf(), calltf(), misctf(),
        Example:
        { usertask, 0, check, 0, func, misctf, "" },
        /*** add customer task entries here ***/
        /* This converts intel binary bit patterns to a verilog readmemb format*/
        {usertask, 0, 0, 0, convert_hex2ver,   0,  "",  1},
    {0} /*** final entry must be 0 ***/
    /* mti interface */
    void init_usertfs()
     p_tfcell usertf;
     for (usertf = veriusertfs; usertf; usertf  ) {
      if(usertf->type == 0)
        return;
      mti_RegisterUserTF(usertf);
  • Compile and link the two C source files (veriuser_mti.c and convert_hex2ver.c). For example:
    gcc -c -I/<full_path_to_modelsim>/include convert_hex2ver.c
    gcc -c -I/
    <full_path_to_modelsim>/include veriuser_mti.c
    ld -G -o altera.sl convert_hex2ver.o veriuser_mti.o
  • Create and edit a local copy of modelsim.ini to include the following information:
    Veriuser = /<full_path_to_where_you_created_altera.sl>/altera.sl
  • Compile the Verilog Source file using the vlog command. You should see the following messages while analyzing the file using vlog:
    Loading work.<design_name> Loading /<full_path_to_where_you_created_altera.sl>/altera.sl
  • Proceed with simulation.
Updated 3 months ago
Version 2.0
