Knowledge Base Article
How do I change the voltage of an I/O bank using the Pin Planner in Quartus II software?
Description
To change the I/O bank voltage in the Pin Planner using Quartus® II software, you can do the following (example using IOBANK_1):
- Launch the Pin Planner (Shortcut: CTRL Shift N)
- Right click the background of the Pin Planner and choose "Show I/O Banks".
- Right click the text box for IOBANK_1 and choose "I/O bank properties ..."
- Set the I/O bank VCCIO to your preferred voltage value.
Updated 2 months ago
