Knowledge Base Article
How do I change the displayed name for a signal in the SignalTap II Logic Analyzer?
Description
In the SignalTap™ II Logic Analyzer, you change the displayed name for a signal by typing a new name in the Alias column or by selecting Set Alias from the Edit menu.
There is also a Rename command available from the context menu by right-clicking a signal name. This command is used to tap a different signal, not to change the displayed name.
Resolution
Updated 1 month ago
Version 2.0
