Knowledge Base Article
How do I change Platform Designer font size ?
Description
Due to a limitation in the Platform Designer software, the font size is not dynamically adjusted based on the monitor resolution and size. As a result, the text may appear too small on high DPI monitors.
Resolution
You can modify the font size by setting the environment variable QSYS_FONTSIZE to the desired point size, for example, QSYS_FONTSIZE=15.
Updated 2 months ago
