Knowledge Base Article
How do I access the UniPHY CSR registers?
Description
In Quartus® II software and IP version 11.0, there is an issue accessing the Control and Status registers in the UniPHY based memory controller.
The latest External Memory Interface (EMIF) handbook shows the UniPHY register map and Controller register map as 9-bit addresses (UniPHY at 0x000 and Controller at 0x100). In the actual implementation, the controller CSR address width is 19-bits and the addresses for the register maps specified in the EMIF handbook are incorrect. The following table outlines the correct register maps for 11.0:
UniPHY Register Map
EMIF Handbook Incorrect Address
Correct Address
Description
0x001
0x0_0004
Reserved
0x004
0x0_0010
UniPHY Status Register 0
0x005
0x0_0014
UniPHY Status Register 1
0x006
0x0_0018
UniPHY Status Register 2
0x007
0x0_001C
UniPHY Memory Init Param Reg 0
Controller Register Map
Correct Address
Description
0x100
0x4_0000
ALTMEMPHY status/control register
0x110
0x4_0040
Controller status/config register
0x120
0x4_0080
Memory address size register 0
0x121
0x4_0084
Memory address size register 1
0x122
0x4_0088
Memory address size register 2
0x123
0x4_008C
Memory timing parameter register 0
0x124
0x4_0090
Memory timing parameter register 1
0x125
0x4_0094
Memory timing parameter register 2
0x126
0x4_0098
Memory timing parameter register 3
0x130
0x4_00C0
ECC control register
0x131
0x4_00C4
ECC status register
0x132
0x4_00C8
ECC error address register
This issue is fixed in the Quartus II software version 11.1.
Updated 1 month ago
Version 3.0
