Knowledge Base Article
How can I use VSEC registers in my Hard IP for PCI Express?
Description
The following is a framework for implementation of VSEC register usage.
Resolution
1) Set up your VSEC memory in the FPGA fabric using Internal RAM.
2) In the Altera® Vendor-Specific (VSEC) Extended Capability Header (offset 0x200), set bits [31:20] to 0x400 (reserved space for the HardIP, other reserved locations are also available)
3) Decode the TLPs that target the range 0x400 plus ( ) the size of memory needed for new VSEC capability
4) Ensure VSEC memory is decoded and encoded through application layer logic
Updated 3 months ago
