Knowledge Base Article
How can I select Active Serial x4 (ASx4) mode when converting a .sof file to a .jic file when using the quartus_cpf command?
Description
By default, when using quartus_cpf to convert a .sof file to a .jic file, the file will be generated for Active Serial x1  (ASx1) mode. To generate the file for Active Serial x4 (ASx4) mode, use a .cof file generated with this setting selected, or use the following switch in your command :
--configuration_mode=ASx4
Updated 2 months ago
Version 2.0
