Knowledge Base Article
How can I print a schematic on 11"x17" paper?
Description
Due to a problem in the Quartus® II software on Windows operating systems, Block Diagram Files (.bdf) may not fit a full schematic when printing on a single sheet of 11"x17" paper.Resolution
To work around this problem, follow the directions below.
- In the Quartus II software, open the .bdf.
- On the File menu, click Page Setup. Change the Size to 11x17. Edit the orientation and margins as needed.
- Close the .bdf.
- Reopen the .bdf.
- On the File menu, click Print...
- To print as an XML Paper Specification (.xps) format, choose Microsoft XPS Dcoument Writer in the list of printers. You can also print as a PDF if you have the option.
- Open the .xps in XPS Viewer or the PDF in Adobe Reader.
- Print to your printer.
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 3 months ago
