Knowledge Base Article
How can I place an image from a Graphic Design File (.gdf) or a Simulator Channel File (.scf) into a Microsoft Word document?
Description
You can copy and paste an image from MAX PLUS II directly into Microsoft Word. If you want to edit the image before placing it into Microsoft Word, perform the following steps: 1. Copy the image in MAX PLUS II and paste it into Microsoft Paint (Windows 95 and Windows NT 4.0) or Microsoft Paintbrush (Windows 3.x and Windows NT 3.51). 2. Edit the image and save it as a Windows bitmap file (.bmp). 3. In Microsoft Word, use the Picture command (Insert menu) to select your bitmap file and insert it into your document.
Updated 3 months ago
Version 2.0
