Knowledge Base Article
How can I observe the Hard IP for PCI Express PIPE interface signals for Arria V GZ and Stratix V devices?
Description
To use the Hard IP for PCI Express® test bus in conjunction with SignalTap™ II, a register map, or general purpose IOs to observe the PIPE interface signals on Arria® V GZ and Stratix® V devices. Follow the instructions below:
The test bus consists of test_in bus and test_out bus. The test bus is designed for debugging purposes only and should not be used in production designs.
The test_in bus determines which Hard IP PIPE interface signals to route to the test_out bus for observation.  The upper 32 bits of the test_in bus in the file altpcie_sv_hip_ast_hwtcl.v is used to select two of eight PCIe lanes. The PIPE signals for these two lanes are routed to the 320 bit test_out bus (also refered to as testout in the same file).
1. Determine the value for the upper 32 bits of the test_in bus
Only the upper 32 bits of the test_in bus are used to select the PIPE interface signals for two specific PCIe lanes at a time. Table 1 shows the test_in[63:32] value to select the lanes.
test_in[63:32] PIPE Interface Signal Lane Selection
32'h0 lane0 and lane1
32'h1 lane2 and lane3
32'h2 lane4 and lane5
32'h3 lane6 and lane7
Table 1. Test_in[63:32] Value to Select Different Lanes
2. Set the value of test_in[63:32] in the file altpcie_sv_hip_ast_hwtcl.v
In the file: altpcie_sv_hip_ast_hwtcl.v, change line 2929
From
.test_in ({testin[63:1],(ALTPCIE_SV_HIP_AST_HWTCL_SIM_ONLY==0)?1'b0:testin[0]}),
To
.test_in ({32’h<n>,testin[31:1],(ALTPCIE_SV_HIP_AST_HWTCL_SIM_ONLY==0)?1'b0:testin[0]}),
Note <n> = 0 to 3 based on the above table
3. Observe the PIPE interface signals from testout in the module altpcie_sv_hip_ast_hwtcl
You can observe the corresponding PIPE interface signals on the 320 bit test_out bus, also referred to as testout, in the module altpcie_sv_hip_ast_hwtcl. The following table shows the PIPE interface signals for particular lanes on the testout bus. You can observe the testout bus using SignalTap™ II, register map, or general purpose I/Os.
PIPE Interface Signals Bit Width Lane 0/Lane 2/Lane 4/Lane 6 Lane 1/Lane 3/Lane 5/Lane 7
reserved - not used 58 testout[159:102] testout[319:262]
lanereversalenable 1 testout[101] testout[261]
eidleinfersel 3 testout[100:98] testout[260:258]
txdeemph 1 testout[97] testout[257]
txmargin 3 testout[96:94] testout[256:254]
rate 2 testout[93:92] testout[253:252]
rxstatus 3 testout[91:89] testout[251:249]
rxelecidle 1 testout[88] testout[248]
phystatus 1 testout[87] testout[247]
rxvalid 1 testout[86] testout[246]
rxblkst 1 testout[85] testout[245]
rxsynchd 2 testout[84:83] testout[244:243]
rxdataskip 1 testout[82] testout[242]
rxdatak 4 testout[81:78] testout[241:238]
rxdata 32 testout[77:46] testout[237:206]
powerdown 2 testout[45:44] testout[205:204]
rxpolarity 1 testout[43] testout[203]
txcompl 1 testout[42] testout[202]
txelecidle 1 testout[41] testout[201]
txdetectrx 1 testout[40] testout[200]
txblkst 1 testout[39] testout[199]
txsynchd 2 testout[38:37] testout[198:197]
txdataskip 1 testout[36] testout[196]
txdatak 4 testout[35:32] testout[195:192]
txdata 32 testout[31:0] testout[191:160]
Resolution
Updated 2 months ago
Version 2.0
