Knowledge Base Article
How can I map registers to I/O elements (IOEs) through Synplify version 6.<I>x</I> and higher?
Description
Altera® recommends that I/O cell register assignments are made in the Quartus software. However, you can implement these assignments in Synplify as well using the syn_useioff attribute on a global or local basis.
You can set this globally by setting syn_useioff=1 on the top level, directly in the source code, through the Synplify settings tool SCOPE, or directly in the constraint file.
Table 1. Setting syn_useioff=1 Globally
Programming LanguageSyntax
Verilog HDLmodule test (d, clk, q) /*synthesis syn_useioff=1 */;
VHDLarchitecture rtl of test is
attribute syn_useioff : boolean;
attribute syn_useioff of rtl: architecture is true;
Constraint filedefine_global_attribute syn_useioff 1
Table 2. Setting syn_useioff=1 Locally
Verilog HDLmodule test (d, clk, q);
input [3:0] d;
input clk;
output [3:0] q /*synthesis syn_useioff=1 */
reg q;
VHDLentity test is
port (d: in std_logic_vector [3 downto 0];
clk: in std_logic;
q : out std_logic_vector[3 downto 0];
attribute syn_useioff of q : signal is true;
end test;
Constraint filedefine_attirbute {p:q[3:0]} syn_useioff 1
Updated 1 month ago
Version 2.0
