Knowledge Base Article
How can I implement HPS LOAN IO and confirm timing?
Description
Final timing models for LOAN IO are included in the Quartus® II software version 14.0, and can be used to confirm timing. Preliminary timing models for LOAN IO are available through a patch for Quartus II software version 13.1 (see related solution below)
Resolution
Procedure to use LOAN IO :-
- In HPS Megawizard, select “Peripheral Pins” tab
- In “Peripherals Mux Table”, select the desired LOAN IO pins
- At Qsys "System Contents", export h2f_loan_io conduit
- Table 1 shows the generated conduit signal interface in Qsys
- Compile the design and generate the preloader with bsp-editor
Table 1
Conduit name | Direction | Declarations |
._hps_io_gpio_inst_LOANIOXX | Bi-direction | Declare as top level pin, pin assignment is hardcoded |
._h2f_loan_io_in [N:0] | Out | Output signal pin from FPGA region user logic, input to HPS region |
._h2f_loan_io_out [N:0] | In | Input signal pin from FPGA region user logic, output to HPS region |
._h2f_loan_io_oe [N:0] | In | Output enable for IO buffer at HPS region |
Notes:
- XX denotes the specific selected HPS IO pin number
- N denotes the maximum number of HPS IO pins, Cyclone V consists of a maximum of 67 pins while Arria V consists of a maximum of 71 pins
- No warning messages are shown in Quartus II if user assigns user logic to the wrong loan_io signal pins
Related Articles
Updated 1 month ago
