Knowledge Base Article
How can I generate IBIS models for Arria 10 or MAX 10 JTAG pins?
Description
You can generate IBIS models for Arria® 10 device or MAX® 10 device JTAG pins in the Quartus® Prime software version 15.0 and later.
Resolution
To generate IBIS models for Arria 10 device or MAX 10 device JTAG pins directly from the Quartus Prime software, do the following :
1. Ensure your EDA Tool Settings are correctly enabled to generate IBIS files
Settings > EDA Tool Settings > Board-Level > Board-level Signal Integrity Analysis Format: IBIS
2. Include a JTAG IP in your design (e.g. Altera Soft Core JTAG I/O IP).
3. Run compilation and you will see the IBIS file in the directory below:
<design_top_directory>/board/ibis/<design_top.ibs>.
This file will contain models for the JTAG pins.
Updated 3 months ago
