Knowledge Base Article
How can I generate Configuration via Protocol (CvP) programming files using the quartus_cpf command?
Description
You can create CvP files for configuration by using the following command:
    quartus_cpf -c <input_file> <output_file> --cvp
You will be able to get CvP files (<filename>.periph.* and <filename>.core.rbf) for your CvP configuration.
To learn more about CvP configuration scheme in the Intel® Arria® 10 FPGA, refer to Intel® Arria® 10 CvP Initialization and Partial Reconfiguration over PCI Express User Guide.
Updated 1 month ago
Version 2.0
