Knowledge Base Article
How can I dynamically change the Stratix® V Hard IP for PCIe configuration registers' content?
Description
The Stratix® V Hard IP for PCI Express® configuration registers' content can be dynamically modified through the Hard IP Avalon® Memory-Mapped (Avalon-MM) reconfiguration interface.
Resolution
Follow the steps below to use the Avalon-MM reconfiguration interface to access the Hard IP PCIe configuration registers.
1. Instantiate either a lpm_constant or a ROM to source the address to the Hard IP AVMM interface.  The attached example design uses a ROM to provide both address and data.
2. Decode the LTSSM state to modify the PCIe configuration register before the link enters L0.
3. Implement a state machine to read/write the desired PCIe configuration register through the Hard IP Avalon-MM interface.
Download the StratixVHipReconfig.zip for an example implementation.  The state machine that dynamically modifies the PCIe Device ID and Vendor ID is located in the hip_eq_dprio module inside <example_design_path>/pcie_lib/altpcie_hip_256_pipen1b.v.
Updated 2 months ago
Version 2.0
