Knowledge Base Article
How can I create a Raw Programming Data file for remote update of a specific CFM location in Intel® MAX® 10 devices?
Description
In the Quartus® II software version 14.1 and later, you can create a Raw Programming Data file (RPD) to remotely update the flash memory in the Intel® MAX® 10 device.
This file can be created in the Convert Programming Files utility when generating a POF file from the compilation-generated SOF file.
The RPD file will include data for the Initialization Configuration Bits (ICB), User Flash Memory (UFM,) and Configuration Flash Memory (CFM) locations. A memory map file is also generated, indicating each location's start and end addresses.
Resolution
To create an RPD file that only contains data for a particular CFM location, simply reference the memory map file and edit the RPD file by removing the data up to the start address of the target CFM location and after the end address of the target CFM location.
Updated 1 month ago
Version 2.0
