Knowledge Base Article
How can I control the logic cell insertion in VHDL designs when using Synopsys (Design Compiler or FPGA compiler) and the MAX PLUS® II software?
Description
You may need to inserting a logic cell for routing or reducing the fan-out of a signal. The flow is:
  1. Instanciate an logic cell component in your hardware description language (HDL) source code.
  2. Add the Synopsys directive set_dont_touch on the logic cell instance name.
  3. Add the MAX PLUS II software logic assignment STYLE=WYSIWYG on this logic cell.
The following example (ilf.vhd and ilc.scr) describes how you can insert logic cell between a XOR gate and a flip-flop. Synopsys synthesizer (Design compiler or FPGA compiler) process ilc.vhd and ilc.scr to generate a MAX PLUS II EDIF file. This EDIF file contains the LCELL instanciation and the STYLE=WYSIWYG logic assignment.
---    Insert an LCELL
---    ilc.vhd
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY ilc IS
PORT(  dina, dinb, clk : IN STD_LOGIC;
dout    : OUT STD_LOGIC);
END ilc;
ARCHITECTURE a OF ilc IS
signal foo_in,foo_out : std_logic;
COMPONENT LCELL PORT ( a_in : IN STD_LOGIC;
       a_out: OUT STD_LOGIC);
END COMPONENT;
BEGIN
U0 : LCELL port map (foo_in,foo_out);
foo_in <= dina XOR dinb ;
flip_flop: PROCESS(clk)
BEGIN
IF clk'event and (clk = '1')
THEN dout <= foo_out;
END IF ;
END PROCESS ;
END a;
/*   ilc.scr                                              */
/*   Synopsys script for design compiler or FPGA compiler */
read -f vhdl ilc.vhd
set_dont_touch find(cell,{U0}) true
set_attribute find(cell,{"U0"}) "LOGIC_OPTION" -type string "STYLE=WYSIWYG"
compile
write -f edif -hier -o ilc.edf
Updated 27 days ago
Version 2.0
