Knowledge Base Article
How can I compile multiple .vqm files if they contain the same entity names?
Description
If your Quartus® II project uses multiple Verilog Quartus Mapping (.vqm) files generated from a third-party synthesis tool such as Synplify, you may find that the same entity name may be used within each. If you compile these .vqm files in the Quartus II software, you may see the following warning due to namespace conflicts:
Critical Warning (12050): Ignored duplicate entity "<entity name>" in file <file 1>.vqm. Used entity in file <file 2>.vqm
To avoid these warnings, compile each .vqm file into a separate design library. See the section Design Libraries in the chapter Quartus II Integrated Synthesis (PDF) of the Quartus II Handbook for details on how to specify design libraries when adding .vqm files to your project.
Updated 22 days ago
Version 2.0
