Knowledge Base Article
How can I batch convert MIF files to HEX files?
Description
The following Tcl script automates Memory Initialization File (.mif) to Hexadecimal (Intel-Format) File (.hex) conversion with a Quartus® II software utility called mif2hex. Copy and paste the script below into a file named mif_to_hex.tcl, and use the following command to run it: quartus_sh -t mif_to_hex.tcl *.mif
global quartus
if { 0 == [llength (args)] } {
    post_message "Usage: quartus_sh -t [info script] <file name pattern>"
} else {
    set file_pattern [lindex (args) 0]
    foreach mif_name [glob ] {
        # Rename to .hex
        set rootname [file rootname ]
        set hex_name .hex
        if { [catch { qexec "[file join (binpath) mif2hex]
             " } res] } {
            post_message -type error
            break
        } else {
            post_message "Converted  to "
Related Articles
Updated 3 months ago
Version 2.0
