Knowledge Base Article
How can I assign a PLL output clock to a Global Clock Network?
Description
You can assign a PLL output clock to a Global Clock Network by using Intel® Quartus® Prime Software Assignment Editor or define it in your .qsf file.
Resolution
Follow the steps below to make the assignment: in the Assignment Editor:
1) Create a new assignment in the Assignment Editor and then set:
  • Assignment Name = Global Signal
  • Value = Global Clock
  • Enabled =Yes
  • To = <node name> (For example, use the node finder to locate the node name of the PLL output clock such as "pll1:inst|altpll:altpll_component|pll1_altpll:auto_generated|wire_pll1_clk[0]")
2) The assignment list will be updated after the assignment is created.
3) Recompile the design.
4) After compilation, verify your assignment by viewing the "Global and other fast signals" report in Quartus® Prime Standard under Fitter > Resource Section > Global & Other fast signals and in Quartus® Prime Pro under Fitter > Plan Stage > Global & Other fast signals. You will see that the output clock is now connected to a Global Clock.
When entering an assignment in the .qsf file follow these steps:
1) Open the .qsf file and add the following:
set_instance_assignment -name GLOBAL_SIGNAL "GLOBAL CLOCK" -to "<node name>"
2) Recompile the design.
3) After compilation, verify your assignment by viewing the "Global and other fast signals" report under in Quartus® Prime Standard under Fitter > Resource Section > Global & Other fast signals and in Quartus® Prime Pro under Fitter > Plan Stage > Global & Other fast signals. You will see that the output clock is now connected to a Global Clock.
Updated 2 months ago
Version 2.0
