Knowledge Base Article
How can I access the Hard Controller Register Map of the UniPHY-based hard memory controller?
Description
The Hard Controller Register Map is defined in the External Memory Interface Handbook, Volume 3, Chapter 6, Table 6-19. The address map shown here is incorrect. The correct address range starts from address 0x0100 which is the same as Soft Controller Register Map.
Resolution
The address map in the table will be fixed in a future release of the External Memory Interface Handbook
Updated 1 month ago
Version 2.0
