Knowledge Base Article
hotrst_exit Signal Inactive in Soft Reset Controller for Arria V Hard IP for PCI Express IP Core
Description
The hotrst_exit signal is not asserted when the LTSSM exits the hot reset state. This error occurs when you use the soft reset controller to reset the Arria V Hard IP for PCI Express IP Core.
Resolution
No workaround is required. The timing shown in the figure, Hard IP for PCI Express and Application Logic Reset Sequence, is still correct.
Updated 2 months ago
