Knowledge Base Article
HMC Controller IP Core Optional Reconfiguration Features Cannot Be Turned Off
Description
If you turn off Enable ADME and Optional Reconfiguration Logic in the Hybrid Memory Cube Controller parameter editor, the following Arria 10 PHY features should be disabled:
  • Enable Altera Debug Master Endpoint (ADME)
  • Enable capability registers
  • Enable control and status registers
  • Enable prbs soft accumulators
  • Enable odi acceleration logic
Instead, only Enable Altera Debug Master Endpoint (ADME) and Enable odi acceleration logic are turned off. You cannot turn off the other three features.
This issue increases resource utilization by approximately 2400 ALMs. This issue affects all variations of the Hybrid Memory Cube Controller IP core.
Resolution
This issue has no workaround. To turn off these features, contact your Altera representative.
This issue will be fixed in a future version of the Hybrid Memory Cube Controller IP core.
Updated 3 months ago
Version 2.0
