Knowledge Base Article
Hard Memory Interface May Fail VHDL Simulation in Arria V and Cyclone V Devices
Description
This problem affects DDR2 and DDR3, LPDDR2, QDR II, RLDRAM II, and RLDRAM 3 products.
Hard memory interfaces on Arria V and Cyclone V devices may fail VHDL simulation with NC Sim or Aldec Riviera-PRO.
Resolution
The workaround for this issue is to open the generated altera_mem_if_hard_memory_controller_top_arriav.sv file and remove the following parameters:
VECT_ATTR_COUNTER_ONE_MASK
VECT_ATTR_COUNTER_ONE_MATCH
VECT_ATTR_COUNTER_ZERO_MASK
VECT_ATTR_COUNTER_ZERO_MATCH
VECT_ATTR_DEBUG_SELECT_BYTE
This issue will be fixed in a future version.
Updated 11 months ago
Version 3.0
