Knowledge Base Article
Half-Rate Clock Not Connected When Clock Sharing is Enabled
Description
If you generate a memory controller with the High Performance Controller II and Multiple Controller Clock Sharing options enabled in SOPC Builder, the half-rate clock is not connected.
This issue affects all designs that use the high-performance controller II architecture with the Multiple Controller Clock Sharing option enabled in SOPC Builder.
The internal half-rate bridge for the sharing PLL controller does not function.
Resolution
To connect the half-rate clock, perform the following steps:
- Edit the sharing PLL controller top-level file to include the half-rate clock input port as in the following example:
- Edit the SOPC top-level file to connect the half-rate clock from the source to the sharing controller as in the following example:
Verilog HDL
module <variation name> (sys_clk_in,sys_half_clk_in,soft_reset_n,input sys_clk_in;input
sys_half_clk_in;input soft_reset_n;.sys_clk_in(sys_clk_in),.sys_half_clk_in(sys_half_clk_in),.soft_reset_n(soft_reset_n),
VHDL
ENTITY <variation name_master> ISPORT
(sys_clk_in : IN STD_LOGIC;sys_half_clk_in
: IN STD_LOGIC; soft_reset_n : IN STD_LOGIC;COMPONENT <variation
name>_controller_phyPORT (sys_clk_in
: IN STD_LOGIC;sys_half_clk_in : IN STD_LOGIC; soft_reset_n
: IN STD_LOGIC;sys_clk_in => sys_clk_in,sys_half_clk_in
=> sys_half_clk_in,aux_full_rate_clk => aux_full_rate_clk,
Verilog HDL
<variation name> the_ <variation
name>(.soft_reset_n (clk_0_reset_n),.sys_half_clk_in
( <variation name_master>_aux_half_rate_clk_out),.sys_clk_in
(<variation name_master>_phy_clk_out)
VHDL
component <variation name> is port
(-- inputs:signal soft_reset_n : IN STD_LOGIC;signal
sys_half_clk_in : IN STD_LOGIC;signal sys_clk_in :
IN STD_LOGIC;the_<variation name> : <variation
name>port map(soft_reset_n => clk_0_reset_n,sys_half_clk_in
=> out_clk_<variation name_master>_aux_half_rate_clk,sys_clk_in
=> internal_<variation name_master>_phy_clk_out
This issue will be fixed in a future version.
