Knowledge Base Article
Generation fails in 10GBase-R PHY MegaWizard Plug-In Manager when the Number of Channels is set to a value greater than 4 for Stratix IV
Description
On the General Options tab of the 10GBase-R PHY MegaWizard Plug-In Manager, if you set Number of Channels to a value greater than 4, generation fails with the message:
Generation FAILED.
Resolution
Specify a value between 1 and 4.If you require more than 4 channels, instantiate additional 10GBase-R PHY megafunctions..
Updated 1 month ago
Version 3.0
