Knowledge Base Article
Generating a large Qsys (Beta) system might cause memory problems
Description
Generating a large Qsys system with many instances, or generating a system multiple times in a single Qsys session might cause memory problems. These memory problems can result in an error message similar to the following:
Error writing sopcinfo report java.lang.OutOfMemoryError:
Java heap space.
Resolution
Close Qsys and reopen it to clear the memory. To generate
a large system, use the command-line ip-generate options.
Updated 1 month ago
