Knowledge Base Article
Generate Simulation Model Option Gets Disabled
Description
The Generate simulation model option gets disabled after every generation.
This issue affects all configurations.
The simulation model for your design is not generated for the second time.
Resolution
Turn on the Generate simulation model option each time you want to generate a simulation model.
This issue will be fixed in a future version of the DDR and DDR2 SDRAM Controllers with ALTMEMPHY IP.
Updated 1 month ago
Version 2.0
