Knowledge Base Article
Functions Missing From Math Library
Description
If you build a custom embedded math library with the -mhw-mulx switch,
and no other options, the Software Build Tools generate an incomplete
library. Some functions, such as pow(), are missing.
Resolution
You can work around this issue in one of the following ways:
- Omit the
-mhw-mulxoption. Multiply operations on 64-bit arguments will be slower, but all math functions will be present in the library. - Include another library option, such as
-mstack-check(run-time stack check) or-pg(profiling). The library will be larger and slower, but all math functions will be present. - Update to v13.0SP1 or later.
Updated 2 months ago
