Knowledge Base Article
ForLoop Block fl Output Incorrect
Description
The ForLoop block fl output does not work properly, is unusable, and may connect to the v outputThis issue affects all designs that use ForLoop blocks. The design fails.
Resolution
To work around the issue, use the main counter output c and externally compare it with the loop\'s initial value.This problem is fixed in DSP Builder v13.1.
Updated 1 month ago
Version 2.0
