Knowledge Base Article
For EMIF Interfaces on Arria 10 Devices, the Duplicate Qsys Button results in an Error Message
Description
If you attempt to duplicate an Arria 10 EMIF Qsys component using the Duplicate Qsys button, errors occur.
Resolution
The workaround for this situation is as follows:
  1. Change from the current protocol to a different protocol, and then change back to the original protocol.
  2. Qsys automatically connects interfaces that are named the same, but you will have to manually correct these connections.
This problem will be fixed in a future version.
Updated 3 months ago
Version 2.0
