Knowledge Base Article
Fitter fails to place PLLs and errors occur when the zero delay buffer operation mode is used for Stratix V
Description
If you use the zero delay buffer operation mode, the Fitter can't place PLLs and generates messages similar to the following:
Error: Could not place pin <pin name>.
Resolution
Manually place the external clock output node with a location assignment. The location depends on the PLL location and the target device.
Updated 18 days ago
