Knowledge Base Article
Fatal: (vsim-3817) Port "configupdate" of entity "system_altpll_0" is not in the component being instantiated.
Description
Due to a problem in the Quartus® Prime Standard Edition Software version 18.1 and earlier, you may see Fatal Error message mentioned above when simulating VHDL based simulation model of ALTPLL FPGA IP.
Resolution
To work around this problem, update simulation script to use the IP top level wrapper file from <ip name>/synthesis/ directory instead of <ip name>/simulation/ directory.
Updated 2 months ago
Version 3.0
