Knowledge Base Article
Fatal Error: Segment Violation faulting address=(nil), PC=(nil): 0:
Description
Due to an illegal RTL construct, you may see the above error message in the Intel® Quartus® Prime Pro Edition Software version 20.3 and later. This error happens during Synthesis when a System Verilog interface contains a localparam that is dependent on one of its parameters. For example:
// Parameterized interface
interface intf #(
int unsigned WIDTH
input logic data
// localparam that depends on a parameter
localparam DWIDTH = WIDTH;
// modports that allow access to localparam
modport mst (
input data,
import DWIDTH
modport slv (
input data,
import DWIDTH
Resolution
Avoid "import" of "interface localparams" in "modport" description of System Verilog Interfaces.
This RTL construct will display an error message beginning with version 22.1 of the Intel® Quartus® Prime Pro Edition Software.
Updated 2 months ago
Version 2.0
