Knowledge Base Article
Fatal Error: Segment Violation at 0x7f68bde12699
Description
Due to a problem in the Quartus® Prime Standard Edition Software version 22.1 and earlier, you might see this error during compilation in the synthesis stage when assigning a value to a constant using a decimal format.
Resolution
To work around this problem, change the value assigned to hexadecimal format.
Updated 2 months ago
Version 2.0
