Knowledge Base Article
Existing Top Failing Paths report can cause TimeQuest GUI to crash when you run Report Top Failing Paths on a different timing corner
Description
When you run Report Top Failing Paths and no failing paths are found for the current timing report, the generated report says, "No failing paths found".
If you have this Top Failing Paths report that says "No failing paths found" and run Report Top Failing Paths on a different timing corner where failing paths are found, the TimeQuest GUI crashes.
Resolution
Delete any report panels titled Top Failing Paths in the Reports view before running Report Top Failing Paths. You can have a folder called Top Failing Paths in the Report view, but you cannot have a panel called Top Failing Paths.
Updated 3 months ago
Version 2.0
