Knowledge Base Article
Example Design for Arria V with Hard Memory Interface Uses Wrong Clock
Description
This problem affects DDR2 and DDR3, QDR II, and RLDRAM II products.
The hard memory interface fabric in Arria V supports clock
rates up to 267 MHz. The example design provided with the IP is
clocked by pll_afi_clk, at 533 MHz. The example design
should be clocked by pll_half_afi_clk instead.
Resolution
The workaround for this issue is to modify the example design
to use pll_half_afi_clk instead of pll_afi_clk
as the clock.
This issue will be fixed in a future version.
Updated 1 month ago
Version 3.0No CommentsBe the first to comment
