Knowledge Base Article
Ethernet 10G MAC IP: Failure During Elaboration Stage in NCSim/VHDL Simulation
Description
When generating the v16.0 Ethernet 10G MAC IP Core with either of the following settings in VHDL, the auto-generated design fails during elaboration when compiled with the NCSIM simulator.
1. ENABLE_TIMESTAMPING = "1"
or
2. ENABLE_1G10G_MAC = "1GBps/10Gbps" or "Multi-Speed 10 Mbps - 10 Gbps"
Resolution
Use the following command to generate the simulation script.
make-ip-simscript --spd=<spd filename> --compile-to-work
Updated 11 months ago
Version 3.0
