Knowledge Base Article
Error(vcom-19): Failed to access library 'altgxb_lib' at "altgxb_lib"
Description
This error message may occur in the ModelSim®-Altera® simulator when you simulate a VHDL post-fit netlist for certain intellectual property (IP) functions that use the Stratix® GX altgxb megafunction.
The name altgxb_lib is referenced in the VHDL Output File (.vho). The precompiled library in the ModelSim-Altera simulator is named altgxb instead of altgxb_lib.
To resolve this naming inconsistency, map the library name altgxb_lib to altgxb using the following command:
vmap altgxb_lib altgxb
Updated 3 months ago
