Knowledge Base Article
Errors in Figures B-8 and B-9 in IP Compiler for PCI Express v11.0 User Guide
Description
Figure B-8, RX Transaction with a Data Payload Waveform, and Figure B-9, RX Transaction with a Data Payload and Wait States Waveform, in Appendix B, IP Compiler for PCI Express with the Descriptor/Data Interface, of the IP Compiler for PCI Express User Guide contain the following errors:
  • In Figure B-8, the rx_req signal should deassert on the cycle following the cycle in which the rx_ack signal is high.
  • In Figure B-9, the rx_req signal should not assert a second time.
Resolution
This issue has no workaround. It is a documentation issue only.
This documentation issue will be fixed in a future version of the IP Compiler for PCI Express User Guide.
Updated 3 months ago
Version 3.0
