Knowledge Base Article
Errors Converting Nios II IDE Multiprocessor Project
Description
If you try use the nios2-convert-ide2sbt utility to convert an IDE multiprocessor project to the Nios II SBT, error messages appear, and the project fails to generate properly.
Resolution
Create new Nios II SBT application and BSP projects using project settings equivalent to the original Nios II IDE project settings.
Updated 3 months ago
