Knowledge Base Article
Error(332000): ERROR: Argument <clk_object> is an object filter that matches no objects. Specify one matches only one object.
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 23.1 and earlier, you may see the following error in the Intel® Quartus® Prime Pro Fitter compilation stage when the L-Tile/H-Tile Transceiver Native PHY Intel® Stratix® 10 FPGA IP is configured as RX PCS-Core Interface FIFO mode = "Register" and Number of reconfiguration profiles is greater than 1.
"Error(332000): ERROR: Argument <clk_object> is an object filter that matches no objects. Specify one matches only one object."
Resolution
This problem is fixed in the Intel® Quartus® Prime Pro Edition Software version 23.2.
Updated 2 months ago
Version 2.0
