Knowledge Base Article
Error(23721): Cannot place block ref_sys_pll_clk_i0|systemclk_f_0|x_hip|gen_refclk_fgt_bb_[8].enabled.inst in location fgt_refclk_8 because the location cannot drive to core fabric.
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.4, "Export Refclk #8 for use in user logic" and "Export Refclk #9 for use in user logic" are shown as available options in the Agilex™ 7 F-Tile Reference and System PLL Clocks IP. Selecting either of these options will result in Error(23721) in the Logic Generation compilation stage.
Resolution
Exporting Refclk #8 or Refclk #9 for use in user logic is not a supported feature in Agilex™ 7 F-Tile transceivers. Refclk #1 through Refclk #7 may be used for transceiver reference clock use in user logic.
This problem is resolved in the Quartus® Prime Pro Edition Software version 24.3.
Updated 1 month ago
