Knowledge Base Article
Error(22728): Synthesis is run on design with Tile IP for instance <...> but the support logic has not been generated.
Description
You might see this error message at the Synthesis stage when the design uses the .bdf file to instantiate the Tile IP, or you have not ru nthe Quartus® Tile Logic Generation compilation stage.
Resolution
The .bdf file is not a supported method of instantiating the Tile IP.
To avoid this error, instantiate the Tile IP using a Verilog or VHDL file and run the Quartus® Tile Logic Generation compilation stage.
Updated 11 months ago
Version 3.0
