Knowledge Base Article
Error(19433): Transfer between periphery and DSP or RAM (signal name) through logic cell (signal name) will make timing transfer impossible
Description
You might get this error message when compiling design connecting External Memory Interfaces Intel® Stratix® 10 FPGA IP to Block RAM directly by using the Intel® Quartus® Prime Pro Edition Software.
Resolution
You can avoid this error by adding one or more pipeline stages between the External Memory Interfaces Intel® Stratix® 10 FPGA IP and the Block RAM.
Updated 11 months ago
