Knowledge Base Article
Error(19433): Transfer between periphery and DSP or RAM <signal_path> will make timing transfer impossible.
Description
You might see a similar error in synthesis when you connect the Avalon® memory mapped Clock Crossing Bridge to the Avalon or MMR interface of the Intel® Stratix® 10 FPGA EMIF IP in the Platform Designer version 17.1 or earlier.
Error(19433): Transfer between periphery and DSP or RAM <signal_path1> through logic cell <signal_path2> will make timing transfer impossible.
Resolution
None
Updated 3 months ago
Version 2.0
